Tractor Talk Discussion Forum
9N No OIl pessure
D Morgan
08-06-2007 10:21:42
I was blading yesterday and started up a hill when I heard grinding gears. I stopped and the noise stopped, engine never missed a beat. I started back to the shop, no weird noises, or engine problems...but noticed NO oil pressure.
Does this sound like the oil pump failed...or ???
Any thoughts???
Bob
08-06-2007 10:54:15
 Re: 9N No OIl pessure in reply to D Morgan, 08-06-2007 10:21:42
The oil pickup tube probably broke off of the oil pump, and got pulverized by crankshaft/rotating assembly, and is laying in pieces in the bottom of the oil pan. Remove the BIG drain plug/screen assembly and the tube SHOULD be visible centered over the the hole, IF still in place.
d morgan
08-06-2007 12:48:01
 Re: 9N No OIl pessure in reply to Bob, 08-06-2007 10:54:15
I will check....is this a fairly easy fix? still need to drop the pan?
Bob
08-06-2007 13:18:02
 Re: 9N No OIl pessure in reply to d morgan, 08-06-2007 12:48:01
If that's the case, the pan has to come down. The oil pickup tube is soldered into the oil pump cover, so if the tube got mangled, you'll have to find a cover/tube assembly.
