Tractor Talk Discussion Forum
Massey Ferguson 240 w/hydraulic bush hog front end loader.
Edward Simmons
08-05-2007 12:00:28
if you had a 240, and it had a bush hog on it with a front end loader ran by hydraulics, where would you put the hydraulic fluid in at?
MF#1
08-05-2007 18:41:33
 Re: Massey Ferguson 240 w/hydraulic bush hog front end loade in reply to Edward Simmons, 08-05-2007 12:00:28
It depends if the loader is run by the internal hydraulics of the tractor or by an external PTO or crankshaft pulley driven pump. The internal hydraulic fluid is added near the gear shift lever, to the left, large nut, dipstick should be behind your right foot rest. If external, add at the reservoir of the loader, probably one of the greasier spots on it.
