Tractor Talk Discussion Forum
One man's trash.....
Jim.UT
08-04-2007 20:16:42
third party image
I was looking at a guy's stuff today when I saw this tractor on the scrap metal pile. Seems too nice to just scrap. What is it? I didn't crawl over the pile to get any numbers off it.
Dickey
08-05-2007 07:30:50
 Re: One man's trash..... in reply to Jim.UT, 08-04-2007 20:16:42
The seat looks like its off a WC Allis
Ultradog MN
08-05-2007 06:14:33
Jim
I agree it looks like a B.
Serial # should be stamped on a raised flat spot by the shift lever.
Bullet proof old tractors.
I grew up on one.
Trouble with the Bs and Cs is they cost as much to paint, repair, restore as our little Fords but they're only worth about half as much.
I still get a hankering for one now and then.
I know where's a good plow, cultivators and a buzz saw for one.
Best thing about those old Bs and Cs was the wide bench seat that would sit two of you.
Best tractor made to go necking with your sweetheart. Or for hauling grandkids.
olddog
08-05-2007 05:56:50
I thought AC "B" at first, but the handhole under the tank looks more like a CA????? Either worth saving..
Traditional Farmer
08-05-2007 13:11:32
 Re: One man's trash..... in reply to olddog, 08-05-2007 05:56:50
Steering,rear hub,toolbox for no battery,front axle all make it a B.Nothing even close to a CA
Farmer in the Dells (WI)
08-05-2007 04:40:22
Can't see enough from this side. Does it have a starter on the other side? It does appear to have hand brakes. That would make it older than my 1947 and crank start only. Pull it in neutral and give the crank a spin to see if it is free. Serial number is near where the shift handle meets the top of the transmission case. Also looks like a lift handle over the right fender. Is there an implement under it? Those too are highly sought after.
Traditional Farmer
08-05-2007 00:54:44
Its an AC B for sure it appears to have the slab weights on the front if so they are worth as much or more as the rest of the tractor
R2D2
08-04-2007 21:42:58
Arched front axle would be a B. Rear wheels look like a B. Seat and steering wheel are not correct for a B. Is serial # available?
Bus Driver
08-05-2007 05:48:56
 Re: One man's trash..... in reply to R2D2, 08-04-2007 21:42:58
The steering arm out of the steering gear box certainly looks like a B.
JMS/MN
08-04-2007 20:55:11
Looks like an arched axle behind that tire on the white rim. That would make it a Model B. A-B, they're all worth saving- that one looks pretty complete.
old
08-04-2007 20:36:59
Thats a B or a C either way its worth saveing
sammy the RED
08-04-2007 20:23:42
 Re: One man's trash..... in reply to john d, 08-04-2007 20:16:42
Allis-Chalmers model "B" ?
