Tractor Talk Discussion Forum
O.T. 6.5 DIESEL HELP-Calling jdmaris or others too!
Kevin (FL)
08-04-2007 06:02:29
Sorry for the OT post but we're on a family vacation away from home base and our '95 6.5 TD has a loud knocking sound that I've narrowed down to the vacuum pump. I have a new one onboard and also a new pulley. My question to anyone having R&R'd one of these--is this a fairly straightforward job? It looks like the mounting bolts run through the AC compressor bracket and into the tapped holes of the pump. The bolts come in from the rear of the bracket so it may be a little tight as far as bolt head access. I found one forum where it stated I needed a puller to remove the pulley. I will need the center bolt off the old one and what looks like a spacer ring, but will use a new pulley.
If anyone has any tips or advice I'd be grateful. I'm debating doing this "in the parking lot" with limited tools onboard. Also, while climbing grades in the mountains, we get an SES light only in the last part of the climb. I suspect this is a wastegate issue due to no or little vacuum. Last question, if I leave it alone and try to limp home (8 hour run) what's the odds off the vacuum pump disintegrating and leaving us on the side of the road?
Thanks for any advice you could offer.
Bob
08-04-2007 06:12:28
 Re: O.T. 6.5 DIESEL HELP-Calling jdmaris or others too! in reply to Kevin (FL), 08-04-2007 06:02:29
Remove the pump AND bracket, 3 bolts, IIRC. Then, swap the new pump onto the bracket, and reinstall it.
NOT a bad job.
The pulley can be swapped using a puller tool for alternator and powersteering pullies.
Kevin (FL)
08-04-2007 07:19:03
 Re: O.T. 6.5 DIESEL HELP-Calling jdmaris or others too! in reply to Bob, 08-04-2007 06:12:28
Thanks for the quick answer Bob. Do you happen to know if the bracket bolts are different from the bolts that go into the pump? I bought a 13mm end wrench when I bought the pump and also got three new bolts. What I think you're saying is that it's easier to remove the bracket that the pump attaches to. That means a different set of bolts into the block? Are these a different size (hex size)? Reason I'm asking all this is that I only have a few tools onboard since we're on the road. There's a parts house near where we're staying so I'll have to buy whatever wrenches/tools I don't have on hand.
Thanks again for the help.
