Tractor Talk Discussion Forum
Ford 860 LP Gas Regulator
Michael Beck
08-03-2007 18:53:25
I am in need of an early model LP Gas regulator that will work on an 860 Ford Tractor.....Thanks Michael
Glen in TX
08-04-2007 12:12:31
 Re: Ford 860 LP Gas Regulator in reply to Michael Beck, 08-03-2007 18:53:25
The Zenith carb kit probably doesn't include regulator kit as I show last one I put was a C994-6 regulator kit also for about $48 for just that kit. So probably that plus the carb kit.
Glen in TX
08-04-2007 10:18:38
Your 860 should have came with a Zenith LPG carb model PC1-8 which is a combo unit with the regulator made right on the carburetor. The Zenith vaporizer was seperate though. Zenith catalog showed the Ford original carb part no. was C5MV-H that fit 600-860 Ford with 134 or 172 engine. Zenith original LPG carb part no. was 12381 and replacement no. is 12407 which is a PC-1 model and neither of those is no longer listed in new Zenith price sheet but I could find out if they are available new yet. The carb kit K2944 is still available listed new for about $42.00 and is basically the regulator kit. I don't keep the kits but can get them. They are simple to put in. If it's some other kind aftermarket LPG conversion setup then you can use Impco or other type regulators that are still available reasonably new.
Michael Beck said: (quoted from post at 18:53:25 08/03/07) I am in need of an early model LP Gas regulator that will work on an 860 Ford Tractor.....Thanks Michael
