Tractor Talk Discussion Forum
farmall H hydraulics
J.C.
07-31-2007 11:46:03
I've got a single hose out of the left side of my tractor. Does that only lift the implement? Also there is no hydraulic fluid on the dipstick when I checked it? How much and what kind of fluid should I use? Any help in regards to hydraulics would be helpful.
J.C.
Wayne from MN
07-31-2007 12:03:34
 Re: farmall H hydraulics in reply to J.C., 07-31-2007 11:46:03
The single outlet on the right and both outlets on the left are pressure out and gravity return.
Original oil specs were SAE 30 non-detergent. If you are sharing with other implements use the same oil as they do.
nballen
07-31-2007 12:03:17
1) The H (belly pump) has only one-way hydraulics - all three ports (one on left, two on right) are tied together.
2) Depends on how the cylinders are hooked up! ;->
3) Sounds like you need to add oil. Fill per dipstick or as required to achieve full hydraulic operation.
4) Original spec was for 30 Wt Non-Detergent oil.
Note:
If you switch implements between your H and modern tractors, you should use a compatible hydraulic oil to avoid a mish-mash of hydraulic oils in your tractors and implements.
Nathaniel
