Tractor Talk Discussion Forum
massey ferguson 300 combine---engine problem
Dale Bosley
07-26-2007 18:53:11
I have a massey ferguson 300 combine and when the engine gets hot and you shut it off it will not start up again. It will start fine when the engine is cold. If you do shut it off when its hot you can come back an hour later and it will start right up. Any solutions would be highly appreciated.
shawnspeed3
07-27-2007 09:47:19
 Re: massey ferguson 300 combine---engine problem in reply to Dale Bosley, 07-26-2007 18:53:11
sounds like a classic case of vapor loc due to todays poor fuel. next time it does it cool the carburetor fuel filter and fuel pump with a rag soaked in cold water...if it starts up you have fuel boiling in one or all of the three areas. Had the same problem on a VW beetle, fuel pump would get hot and vapor lock , cooled it down with a wet rag, and away I went.....Good luck Shawn
Sam#3
07-26-2007 19:22:06
Capacitors behave like that also. A capacitor is the easier to test. Take it out and run the engine through one cycle. BE AWARE runing without the capacitor will age the breaker points really fast, Only one cycle. However, with that said I usually think fuel problems when they won't re-start. When they DIE and won't start I think ignition.
Randy165
07-26-2007 18:59:32
Sounds like the coil. Wiring inside makes contact when it"s cold...heat causes it to expand...and no contact.
Larry in Mo
07-26-2007 19:29:14
 Re: massey ferguson 300 combine---engine problem in reply to Randy165, 07-26-2007 18:59:32
I had one that did that. Fought it for two years. Come to find out the ceramic resister was cracked and broke the coil inside. Cold, start. Hot, no start. Changed resister and no problem after that. LE
