Tractor Talk Discussion Forum
Aftermarket three point hitch for H or BN
Norm S
07-24-2007 06:39:38
I know I have seen kits for TPHs for H in the past but now that I am ready to buy one I cannot find the source. Can anyone point me to a seller? I"d like to put on on my H and/or BN.
Thanx!
Norm
Spook
07-24-2007 11:36:11
 Re: Aftermarket three point hitch for H or BN in reply to Norm S, 07-24-2007 06:39:38
I put a Saginaw hitch on my H. I think it is better than any O.E.M. unit I have seen. Great design, very sturdy.
Norm S
07-24-2007 11:59:54
 Re: Aftermarket three point hitch for H or BN in reply to Spook, 07-24-2007 11:36:11
Thanks for the review. Did you just use the original hyd pump to run it? And is it power up and down or just up?
Thanx!
Norm
Gary from Muleshoe
07-24-2007 08:17:16
There is one on Ebay right now for a JD B.
georgeky
07-24-2007 07:18:51
Try searching Work Saver or maybe just search three point hitch kits. I would think that Stiener Tractor may also have them. One for the BN may be tough as they have no hydraulic pump on them, unless you have a PTO driven pump or a newer engine in the tractor.
ScottyHOMEy
07-24-2007 07:18:23
Are you thinking of the Saginaw hitch? They've got them for H's and M's. I suppose anything is possible and can be done, but I don't believe I ever saw a three point on a BN. How would you lift it?
Norm S
07-24-2007 10:12:05
 Re: Aftermarket three point hitch for H or BN in reply to ScottyHOMEy, 07-24-2007 07:18:23
Thanks for the info. Where would I get the Saginaw hitch? As for the BN, I would put a hyd. pump on the PTO and add controls. Thought maybe I could even adapt a hitch meant for an H but I'd have to look at it and see if its feasible.
Thanx!
Norm
ScottyHOMEy
07-24-2007 11:04:29
 Re: Aftermarket three point hitch for H or BN in reply to Norm S, 07-24-2007 10:12:05
The link below will take you to Saginaw.
You'll be hard-pressed to adapt anything for the H or M to mount up on the BN. The BN doesn't have the two notches in each shaft housing for anything that heavy to bolt up onto. Cs and bigger have two flat notches on those housings that the Saginaw and other makes bolt up to. The same spot that carries the drawbar on the Hs and Ms.
You could take a look at the plow lift mechanisms on Cubs and Super As to see if there's anything there that you can adapt and fab up to bork on the BN.
Good luck!
georgeky
07-24-2007 07:21:21
Scotty, I sat here for 15 minutes trying to remember Saginaw Hitch and it kept eluding me. Sometimes I barely remember my name.
