Tractor Talk Discussion Forum
how much to fill a funk pump drive on excavator
Tom B (tbone)
07-22-2007 14:38:33
Hi,
I am trying to figure out how much gear oil to put in a funk pump drive on my excavator. It is a triple drive, one on top, two on bottom. There are 4 plugs, two on the top one and two for the bottom two. When you put oil in the top hole, it flows down to the bottom drives. So, do you fill it to the lower drive plugs or up to the upper drive plug??? Sorry if it is a stupid question.
Thanks,
Tom
Tramway Guy
07-22-2007 19:51:48
 Re: how much to fill a funk pump drive on excavator in reply to Tom B (tbone), 07-22-2007 14:38:33
Which model pump drive? Funk made several different triplex drives, differ in HP ratings.
John Deere owns Funk.
My guess is that the lower ones are the ones you want. All the gears turn all the time, so the lower ones splash oil up to the upper ones.
I would think that the oil level would be just below the lowest output shaft.
