Tractor Talk Discussion Forum
Manure spreader chain
Granger
07-20-2007 07:50:48
Just got an older chain driven manure spreader. It sat for 2 years, so I was just wondering what I can put on the chain to "lube" things up a bit??
RodInNS
07-20-2007 10:37:28
 Re: Manure spreader chain in reply to Granger, 07-20-2007 07:50:48
For old flat link chain in a spreader I just use waste oil. Anything at all. Just find a less than obvious place to park the spreader while you "apply" the oil.... Once the spreader is working in manure, I don't worry about it. Those are slow moving, cool running chains, so it's not like they need much lube.
Rod
Pair-a-dice farm
07-20-2007 10:30:26
I agree with old, tranny fluid let it soak a while then run it a little bit and put a thicker oil. Look over all of the links to see if there are any damaged links and repair before you start to load. You do not want to have a chain break and have to shovel it off. I spread a LOT of manure (smelly kind not politician kind). When you are done be sure to clean it up good and oil down the chains.
Walt Davies
07-20-2007 09:54:41
Napa has a spray can of chain lube we used it on the balers chains works great. Leave the chain on the bed that moves the manure down dry or it will just gum it up and wear it out faster.
Walt
sd pete
07-20-2007 09:14:11
I am cheap and use waste oil can mix in a little gas or diesel fuel
Gerald J.
07-20-2007 08:57:13
I'm seeing reports that chain saw bar and chain oil is really good for lubrication chains in other applications. Applied with a long spout pump oiler.
Gerald J.
old
07-20-2007 07:58:36
For things like that I use tranny fluid first then after getting things freed up I use a thicker oil. The tranny fluid cuts the rust and also sinks in deep.
