Tractor Talk Discussion Forum
JD 2010 hyd Quit
RLH
07-10-2007 02:23:32
I lost all hydraulic fuctions on 2010 industrial utility imiditaly where is pump located how do I check it all help appreciated
ben brown
07-10-2007 03:36:37
 Re: JD 2010 hyd Quit in reply to RLH, 07-10-2007 02:23:32
yes there is one up front for loader. there is also one in the belly under a plate. that does the 3pt power steering and hy presure for power shift. there is a screen that can be cleaned rt side behind a plate three bolts spring loaded. remove it clean reinstall sometime you have to replace them. all oil well run out of tractor so need to drain hy fluid first
MyrlfromPA
07-10-2007 04:14:36
 Re: JD 2010 hyd Quit in reply to ben brown, 07-10-2007 03:36:37
there is also a lever on the left side of the clutch housing to take hydraulic pump out of gear.. may want to check that first
IaGary
07-10-2007 03:28:43
Don't you JD guys jump all over me if I'm wrong.
The pump is up in front of the radiator and is shaft driven.
I bet something let loose on that shaft.
Gary
KEHh
07-10-2007 05:06:18
 Re: JD 2010 hyd Quit in reply to IaGary, 07-10-2007 03:28:43
What Ben said plus change the hydraulic oil.
KEH
