Tractor Talk Discussion Forum
john deere b help
jonathan s
07-09-2007 18:40:32
hey guys, i have a 1950-51 john deere b, i got done goign through the motor and i got it running. the problem is that it wont run off choke. only on half choke. i cleand the carb two times in the last four days. im taking it apart again to clean the jet. i was wondering if my three inch straight pipe would cauz my problems? if my three inch straight pipe is the problem what do i need to do. do i need to get a bigger jet? any help will be very much apreciated. jon in northeast pa
MyrlfromPA
07-10-2007 04:24:11
 Re: john deere b help in reply to jonathan s, 07-09-2007 18:40:32
One more thing to ask you is do you have oil in the air cleaner and is it hooked up. the oil bath air cleaner does create the vacume needed for the side draft carb to function properly
greenmech
07-09-2007 20:13:59
You may still have a passage plugged. All those brass plugs need to be removed and the passages cleaned. Also maybe your air cleaner is causing a restriction. One more thing, do you have a good fuel flow from the tank? Good luck. Ron Mn.
johndeereman
07-09-2007 20:10:56
its not youre pipe might be an air leak get it running but not hot and spray carb cleaner or something of the like around all manifold crevises see if the engine speeds up if so there is youre leak oh and where you at in nepa im in granville summit bradford county
jonathan s
07-10-2007 07:17:26
 Re: john deere b help in reply to johndeereman, 07-09-2007 20:10:56
im in susquehanna pa, about 20 miles south of ny state line.
Chris in MD
07-09-2007 19:21:28
You may have a hole in the float.
And no, you could put a 10 inch stove pipe on the exhaust and it will not affect engine performance.
Dlm
07-09-2007 19:12:07
I don"t think the exhaust pipe has any thing to do with the runing. You still have problems with carb. Make sure float level is ok, did you take the nozzle out in the center of carb. Posable that you might have a leaking manifold gkt. On the carb. the drain in the bottom take it out put a barb fitting and a length of clear tubing about 8 in. tie the end up then run your tractor the fuel level should be 3/4 in down from the top of the bowel. Don
