Tractor Talk Discussion Forum
Allis WC missing on #2 #3 cylinder (dead or nearly dead)
Illinois Todd
07-06-2007 13:53:01
I have an 1937 Allis WC that has been overhauled (saved it from the scrap heap), problem I am having is with the engine, it appear cylinder 2 and 3 are not doing any work (1 & 4 are good). I have switched around plugs and wires...made no difference. I used a infared temp gun...confirms that the two cyl are nearly dead, 140 deg vs. 400 to 500 deg on cyl 1 & 4. Pulled the plug wires while running made no difference in idle (spark will jump to the plug). Spark and cam timing are good...it will start with hand crank, idles well and drives but not much power. Appears there getting fuel since plugs are wet and black. Compression test has all cylinders at 55 - 60psi (hot and cold).
Have not checked vacuum yet, a friend said it sounds like a valve is warped and hanging up when at engine speeds (but OK during compression test). I did have the valves lapped and head checked out prior to installing it (not to say there is'nt a problem now).
Anyone have any suggestions before I pull the head?
Thanks!
workhorse
07-07-2007 05:46:00
 Re: Allis WC missing on #2 #3 cylinder (dead or nearly dead in reply to Illinois Todd, 07-06-2007 13:53:01
I had a guy give me a 4 cyl A C engine one time that would only run on 1 and 4. Got it home and switched 2 and 3 plug wires and it ran fine.
shannon from ohio
07-06-2007 20:21:56
Don't let that compression test confuse you?? Head gasket could be blown between cylinders 2&3?? Leakdown test would be more conclusive..... ...
oleblu
07-06-2007 15:34:23
Have you tried switching the #2 and the #3 plug wire in the cap only, as you have #"s 1 & 4 in the right position, but 2 & 3 are not? Worth a shot.
Maark
07-06-2007 14:12:55
You say the plugs are "wet and black". They should be a toasty brown color. replace your plugs, as they are fouled and not firing under compresson.You may need to adjust your load screw on the carb to rid it of excessive fuel.
