Tractor Talk Discussion Forum
Leyland sleeves
Gary rose
07-05-2007 16:33:11
Im putting new sleeves in a 270 leyland and was wondering what seals the top of the sleeve at top? There is two orings on the lower part but it would seem the top would need something also. There wasn't when I pulled the sleeves.
richardinnz
07-06-2007 03:56:36
 Re: Leyland sleeves in reply to Gary rose, 07-05-2007 16:33:11
No seals at the top, the gasket looks after that, just clean the block bore out really well, put a smear of rubber grease on the "O" rings to make insitation easier. When installing the pistons you may have to clamp the liners in to position so as to stop them being pushed out by the pistons when you bar the engine over without the head on.
Gary Rose
07-06-2007 10:19:58
 Re: Leyland sleeves in reply to richardinnz, 07-06-2007 03:56:36
Thank you for the help I guess that all makes sense once it makes sense if you know what I mean Thanks again Gary
J Schwiebert
07-05-2007 18:10:31
That is what the headgasket is for.
