Tractor Talk Discussion Forum
water does not circulate on mm jet star-3
david shields
07-03-2007 10:42:56
the water does not circulate on my mm jet star-3. is thier a grease fitting on water pump the, belt is tight. could thier be a thermostate in this?
old
07-03-2007 13:26:48
 Re: water does not circulate on mm jet star-3 in reply to david shields, 07-03-2007 10:42:56
Could be one of a few problems. Bad thermostat, bad water pump or a clogged up cooling system. I would start with the thermostat
Gary from Muleshoe
07-03-2007 11:23:28
Sounds like your thermostat is stuck in the closed position. Is the engine HOT or COLD when this is happening? If it is cold it will not circulate until the engine warms up and the thermostat opens.
