Tractor Talk Discussion Forum
New Mini Tractor
Deepak Singh
07-02-2007 05:42:00
I'm interested to manufacturea mini tractorof 10 H.P, our tractor is under R&D and we want to launch the Cheap n Best Tractor.if anyone have any idea or design plese support.
RN
07-03-2007 11:20:21
 Re: New Mini Tractor in reply to Deepak Singh, 07-02-2007 05:42:00
Look at old Cub Cadet 104 for ideas/example. Also check Simplicity 700 series. Suggestion - use a 4 speed transmission with extra low 1st gear instead of 3 speed. Iron case transmission/rear end, strong disc clutch and shaft drive for heavy use would be nice- get maximum benefit from 10hp engine. If useing belt primary consider Comet type drive- like snowmobiles- instead of loose belt and idler pulley. RN
Brent Burns
07-02-2007 11:19:55
Keep it simple. I have an old Speedex that has served me well. Would be simple to manufacture and can pull a lot for its size. 10 hp seems too small. Why not go up to 16 hp? That's what I have on mine and it can do a lot more than mow grass. It's all in the gears. Belt and chain drive. Can't get much simpler.
Lanse
07-02-2007 07:20:47
I'm interested. Is this s garden tractor, what attatchments are you thinking of?
Mike (WA)
07-02-2007 12:24:54
 Re: New Mini Tractor in reply to Lanse, 07-02-2007 07:20:47
Lanse- weren't you the guy who just posted on the Chinese tires thread that you didn't buy foreign stuff?
