Tractor Talk Discussion Forum
OT Propane Fueled Engine Problem
Tooly
06-30-2007 22:41:15
I know this probably way off topic , but I was wondering if anyone with a propane tractor has ever run into this problem. I had my propane fueled motor home out the other day, and when I had it refueled the line that is supposed to show when the tank is full to the recommended level seemed to be plugged. Neither gas or liquid propane will come out. Any ideas what would be the cause and what would maybe required to fix it?
Thanks for any info.
Unclemerle
07-01-2007 09:13:10
 Re: OT Propane Fueled Engine Problem in reply to Tooly, 06-30-2007 22:41:15
Tooly
The little rubber gasket will get mashed down into the slot when it is tightened to tight. Just back it out a little and leave it barely snug and it will start to work again (just don't forget about is as it will leak out gas once it breaks loose). This happens all the time on large tanks, no big deal.
Merle
Nebraska Cowman
07-01-2007 04:02:17
If you open the blead-off valve too fast it will pop-off. Try closing it and try again.
