Tractor Talk Discussion Forum
How to pull a steering wheel off an 8N
Terry B
06-30-2007 22:38:40
I took the centre cover nut off the wheel, set a wheel puller into the centre threaded pipe fitting, and hooked the claws to the underside of the wheel mount. But instead of lifting the wheel, the puller split that centre threaded pipe fitting open. Anybody ever pulled a wheel off?
kyle in NY
07-01-2007 06:36:12
 Re: How to pull a steering wheel off an 8N in reply to Terry B, 06-30-2007 22:38:40
I was told by a JD mechanic that you should never beat the post if it is a model with power steering.
Rod in Smiths Falls, ON
07-01-2007 03:33:04
Cutting torch. Replacements are cheap.
Tooly
06-30-2007 22:45:21
I guess this is not much help now, but if the nut would have been backed off, but left on the end of the shaft it may have prevented your problem.
Pitch
07-01-2007 02:50:34
 Re: How to pull a steering wheel off an 8N in reply to Tooly, 06-30-2007 22:45:21
Pull the nut almost off spray it up with apenetrater the beat the bottom of the center with a bfh, yank up on each side of the wheel it will come off.
