Tractor Talk Discussion Forum
336 JD Baler Timing = HOW TO?
Robert Searcy
06-30-2007 17:26:18
I have a neighbor that I am trying to help. He has a 336 baler and no manual and no access to the internet. Do any of you all know how to time one, he said he put on new fingers or something like that and now cannot get it back in time.
Thanks,
Robert
roger in Iowa
06-30-2007 18:56:33
 Re: 336 JD Baler Timing = HOW TO? in reply to Robert Searcy, 06-30-2007 17:26:18
What Old said is correct. You may have to retime the overhead feeder forks and needles. Need an OM for all that. Better find out what caused it to go out of time. Chain wear or broken, sprockets worn, etc.
Roger in Iowa
old
06-30-2007 17:49:08
Have him buy a manual or you will never be able to get it right. It would take 2 or 3 pages to explain timing one on here. The manaul has about 2 or 3 pages that you have to go by step by step to retime a baler. By the way JD dealer will still have a manual for it
Robert Searcy
06-30-2007 18:04:47
 Re: 336 JD Baler Timing = HOW TO? in reply to old, 06-30-2007 17:49:08
okay guys will do, had no idea it was that sophisticated he said that some metal piece came up and broke some fingers off and so he put some new fingers on it and turned it over by hand and this metal piece is sticking up too soon where these fingers are at and said its going to break off the new ones if he doesnt do something to adjust it that is why he thinks its out of time
dan hill
07-02-2007 03:50:09
 Re: 336 JD Baler Timing = HOW TO? in reply to Robert Searcy, 06-30-2007 18:04:47
Kntters can get out of time with each other if there is too much end play in the knotter shaft.I would not work on this without a manual.
buickanddeere
07-01-2007 06:01:06
That's the plunger block rising when ever the needles are in the bale chamber. Better to break a shear pin on the drive instead of busting a pair of needle$. Your neighbour doesn't need internent to call 1-800-522-7448 and order a real manual from Deere at wholesale cost.
Tx Jim
07-01-2007 04:21:49
Robert have you checked YT archives? I explained on 6/22/07 in JD Forum on timing a JD 224T that is the basically the same for 336. Tx Jim
