Tractor Talk Discussion Forum
8N tractor engine barely runs
RTurner
06-30-2007 15:11:37
Here's whats happening with this engine. It's difficult to start, runs rough with black smoke and misses real bad until it just dies and won't re-start. It has the side mount distributor. I've put a carb kit in, new plugs, wires, distributor cap, rotor, points and condensor. It is a 6 volt system. I do have spark at the plugs, rather weak however that probably just the 6 volt. Any idea's? Thank you!
Kenster
07-02-2007 07:09:03
 Re: 8N tractor engine barely runs in reply to RTurner, 06-30-2007 15:11:37
RT, you should post this on the 9N, 2N, 8N board on this website. Lots of experts there that are very familiar with the 8N.
roger roland
06-30-2007 22:32:15
im not gonna be any help but i think your problem might be its a ford ? lol just had to add
old art
06-30-2007 20:25:07
try it with out the air cleaner pipe connected and see what happens it may be flooding if it is look for a float that is leaking and full of fuel . if it runs good with the air cleaner disconnected the air cleaned is pluged up.
CNESLER
06-30-2007 15:16:40
Black smoke is to much fuel
CNESLER
RTurner
06-30-2007 15:46:32
 Re: 8N tractor engine barely runs in reply to CNESLER, 06-30-2007 15:16:40
I set the carb to the specs that came with the kit.
old
06-30-2007 17:46:17
 Re: 8N tractor engine barely runs in reply to RTurner, 06-30-2007 15:46:32
Black smoke says you did something wrong in that carb. Maybe the float is set wrong or has a hole in it, or you didn't get the float needle seat tight enough. These carbs are simple but hard to really get as clean as they need to be and you may have missed some junk in it and that will also cause you problems
Farmall MD
06-30-2007 15:53:21
Specs that come with the kit will get you close to where it has to be, you still have to fine tune it. It is running way too rich. Don't know too much about Fords, but a carb is a carb. Turn the main fuel adjusting screw in about 1 to 1-1/4 turns, and go from there. Or the float could be stuck. Is it dripping fuel out of the bottom?
When you have the right mixture, the plugs should be a medium tan in color. Doug
