Tractor Talk Discussion Forum
Idler pully fix questions
old
06-26-2007 17:42:19
I have an old hay rake that has an idler pulley in it and the bearing is wore out. Have any of you ever tried to split one of these stamped steel pulley apart and put in a new bearing?? This one looks like it has rivits holding it togeather and I'm thinking about tring to split it and put in a new bearing. Any ideas on this or I'm I #1 crazy and #2 to cheap to pay $350 for a new one??
Thanks
NawlensGator
06-27-2007 11:03:51
 Re: Idler pully fix questions in reply to old, 06-26-2007 17:42:19
For 35 bucks i'd buy two.
David Snipes
06-27-2007 08:05:25
I did it and used bolts to reassemble the pulley. The bearing I bought to put in it was only $10.00.
souNdguy
06-27-2007 07:15:57
Not one one in that application.. though i have driled out rivits on stamped pulleys and then used nuts/bolts to putem back together.. etc..
pay 350$ for an 12$ bearing.. I'm cheap just like you are.. try to split her.. worst case scenerio is you are buying the pully if you muck it up..
Soundguy
Southern Ray
06-27-2007 06:29:37
Is the bearing gone or just dry. Try removing the side seals, clean it out insides, regrease it, and put it back together. I"ve done this many times.
old
06-27-2007 07:44:10
 Re: Idler pully fix questions in reply to Southern Ray, 06-27-2007 06:29:37
Bearing is gone you can see that it has a few balls missing in it and the center flops around a good bit
Rex in Australia
06-27-2007 04:03:15
I have done them on a few ocassions. Generally a common bearing inside, replace the rivets or spot welds with screws/nuts, or rivet them over whichever you want.
Works ok and is cheaper.
Rex
Jiles
06-26-2007 19:10:17
I do things like this very frequently. Did the exact same thing on a Wheel Horse lawnmower. I replaced the rivets with 1/4" dolts. The dealer wanted $24 for the assembly, fixed mine for less then $6. But I have more time then money!
Clint Youse MO
06-26-2007 18:45:23
Unless time is free which is not to me you will still end up with $35 in it by the time you split it find a bearing put it back together your choice I have done both in certain situations.
Clint
RWT
06-26-2007 18:26:47
I think you are stuck. I split one on a Kinze planter to look at and the metal rivited together was the outer race. Nothing to replace.
RT
Roger in Iowa
06-26-2007 18:01:41
I remove the rivets and install bolts or pop rivets (steel) or even drill more holes and put in more rivets if space allows.
The bearing races should have numbers on them to cross to a new bearing or take the bearing to a distributor and they can fix you up.
Been there, done that!
Roger in Iowa
old
06-26-2007 17:43:37
That should be $35 not $350.
