Tractor Talk Discussion Forum
IH 460 Diesel
Chestnut
06-26-2007 06:06:35
How many Utility 460's had the 560 282ci diesel engine?
JOHN HARMON
06-26-2007 14:14:46
 Re: IH 460 Diesel in reply to Chestnut, 06-26-2007 06:06:35
None from the Factory. D236 Diesel and C221 CID Gas were production engines for the 460 International and Farmall. Changes could have been made for any number of reasons. A lot of Warranty work was on a ,what is in stock basis.Or some Hot roddding to aquire more power could be done at a Dealers Shop.
Owen Aaland
06-26-2007 11:48:23
My 460 Diesel has a block in it that is stamped 282 but it is really still the original size for the tractor. The original block was broken and a used 560 block along with the original 460 crankshaft were used for repair. New replacement blocks did not have a size stamped on them.
Jimmy King
06-26-2007 18:34:36
 Re: IH 460 Diesel in reply to Owen Aaland, 06-26-2007 11:48:23
The 236 and the 282 used the same block, different crankshaft the bore is the same but the stroke is longer on the 282.
migraine
06-26-2007 08:40:47
None from the factory, they had the 236. But with a change to a 282 crankshaft, you could have a 560 motor. The motor mounts for the utility are different than the Farmall since there was never a 560 utility made. Migraine
chestnut
06-26-2007 13:28:59
 Re: IH 460 Diesel in reply to migraine, 06-26-2007 08:40:47
So what you two are saying is that this is a 460 Utility and IH used blocks stamped 282 but built them as a 236. Or were these built with 282 sleeves and pistons and a 460 crank which I assume has shorter throws. Can you clarify this?
Thanks
