Tractor Talk Discussion Forum
ford running hot
clewis
06-24-2007 17:47:47
I recently bought a ford 3000 and it started running hot not long after I had it. I checked the radiator and drained it and it looked to have oil in the water. I filled it back up with water and antifreeze and it run hot again. I drained the water again and it was black like before with the look of oil. Does anyone have an idea what this might be?
clewis
06-25-2007 08:42:22
 Re: ford running hot in reply to clewis, 06-24-2007 17:47:47
could the head be cracked?
RodInNS
06-25-2007 11:57:33
 Re: ford running hot in reply to clewis, 06-25-2007 08:42:22
Could... but I doubt it. Gasket, most likely.
Rod
Tom in TN
06-24-2007 21:49:22
clewis,
I have a Ford 2000 gas that had a problem with overheating. I did all of the common things - flushed radiator multiple times, removed thermostat, tested for compression leaks, adjusted timing, added "cooling" additives to water, replaced radiator cap, etc. I finally pulled the radiator and took it to a radiator shop to have it "boiled" out. The guy said it was plugged too badly to fix it. I put in a new radiator and it has been absolutely perfect ever since.
Good luck with yours,
Tom in TN
paul
06-24-2007 21:28:55
Hope for it just to be left over gunk, but....
Head gasket or maybe cavitation. Either way oil & water are mixing through holes that should be seperating the 2, & major tear-down. Cavitation is more likely in a diesel.
--->Paul
Leland
06-24-2007 21:06:02
try a pressure washer or air hose it may need the rad washed out the fins may be blocked try this first . The fan sucks a lot of crap in and this is a common problem besides it's the easiest and cheapest thing to do first
Leland
06-25-2007 04:16:56
 Re: ford running hot in reply to Leland, 06-24-2007 21:06:02
never mind I miss read this post 1/2 asleep
jmixigo
06-24-2007 19:04:24
Head gasket.
clewis
06-26-2007 11:33:03
 Re: ford running hot in reply to jmixigo, 06-24-2007 19:04:24
thanks for input
