Tractor Talk Discussion Forum
Urgent help needed on Head bolt specs
farmall newbie
06-24-2007 16:54:23
I am ready to re-install the head on a Farmall M, serial number FBK240103 and need the Torque in foot pounds and tightening sequence. Thanks in advance. You may reply here or send a message to [email protected] Please.
JMS/MN
06-25-2007 11:27:37
 Re: Urgent help needed on Head bolt specs in reply to farmall newbie, 06-24-2007 16:54:23
Some sequences are different, but generally like old says, plus alternate from side to side at the same time, rather than one complete side, then the other.
old
06-24-2007 18:56:54
Torque is 110FT/lbs. Can't tell you the other, other then work from the middle out. Pretty much the same on all engines
Jerrycpp(WA)
06-26-2007 08:08:09
 Re: Urgent help needed on Head bolt specs in reply to old, 06-24-2007 18:56:54
The pattern is designed to work any warp to the ends. Start in middle and work out in a circular pattern, like a spiral. You should end up at one corner.
newby
06-26-2007 08:50:39
 Re: Urgent help needed on Head bolt specs in reply to Jerrycpp(WA), 06-26-2007 08:08:09
Thanks for the help fellows.
