Tractor Talk Discussion Forum
PHOTO - Highland Cattle
David in Wales
05-31-2007 11:12:05
third party image
Hi Gang;
A few weeks ago you were asking about Highland cattle, well we found some. Typical "pets" in a field next to a house. Hope you enjoy.
Cheers David
bobby simpson
01-17-2008 09:35:39
 Re: Kubota L210 questions in reply to James D, 12-18-2000 16:55:27
need price for starter and injectors and availability of parts
Bob Kerr
01-17-2008 09:00:33
 Re: OT trailer floor in reply to bhb, 01-17-2008 07:22:33
White oak all the way! Get wood that doesn"t have any sap wood on the edges. It is considered a boat building wood and is tough stuff! I would not use rough cut as it leaves low spots for water to collect and will let fungus get started. As for water proofing, Mopping it down with used motor oil mixed with kerosene to thin it works exellent, and you get a new supply everytime you change oil in something.Also put some in an old sprayer with some kero to thin it and spray the underside. Main thing is to not let fungus get started in the wood. If you are worried about skidding on the oil just toss sand over it afterwards. The only drawback is if it gets wet with the oil on it, it will get slick! the first year or two put the oil on twice a year and after that once a year should be good if you oil it in the fall when you are done for the winter. If you do all that the wood might outlast the trailer!
Walt Davies
05-31-2007 11:18:16
 Re: PHOTO - Highland Cattle in reply to David in Wales, 05-31-2007 11:12:05
Heck all i need to do is drive down the neighbors place has a couple of those. drive around the corner and the next guy has Buffalo and then turn back and go south to the farm we work and a guy has long horn sheep. it a regular Zoo around here.
Walt someday i will try to get some pics but those long horns sheet are very shy.
