Tractor Talk Discussion Forum
Tractor fuel use
cj3b_jeep
05-31-2007 10:06:37
So I was mowing the neighbor's field last night and the night before in trade for the building material I spoke about last week. I mowed for three hours tuesday night and three last night. I used just about 1 gallon of diesel each night. This is a David Brown 880e 3 cylinder. I was running around 1750 rpm with the pto in low for around 540 rpm. Seems like great fuel economy, I always knew it was easy on fuel, but that seems really low to me.
Leland
01-17-2008 09:11:31
 Re: Sold tractor on ebay should I be worried. in reply to Jersey boy, 01-16-2008 16:44:17
just don't release the tractor for export until the check or money wire clears and is in your account
greygoat
01-17-2008 09:10:52
 Re: What else is happening? in reply to rrlund, 01-15-2008 10:29:48
West Central Wisconsin, Mississippi River Valley
about 20 miles north of Iowa, Minn. border
It's snowing pretty good, and about 15 degrees.
Expecting 6 to 10 inches and below zero tonight.
Predicted high of 5 Friday, low of -17 below on
friday night and daytime high of zero on Saturday.
Pretty soon we'll be complaining about Mosquitos.
Greg_Ky
01-17-2008 08:57:26
 Re: hydroulic top link in reply to Greg_Ky, 01-17-2008 08:54:54
Should have added that the unused end must be vented or it will not work.
Mike M
05-31-2007 12:40:02
 Re: Tractor fuel use in reply to cj3b_jeep, 05-31-2007 10:06:37
Around 3/4 gal an hour is about all the better I've seen on small diesels mowing the lawn. If you can get that good someone better put that engine in a small pickup !!!!!
Midwest redneck
05-31-2007 12:37:29
I rented a diesel tractor 3 or 4 years ago (it had the 1 liter diesel 3 cyl. in it) and in about 6-7 hours I used only 2 gallons of diesel. (not bad)
dej(jed)
05-31-2007 12:08:31
I have both a Long 445 and a David Brown 995. They are both extremely easy on fuel. They are fuel sipers.
souNdguy
05-31-2007 11:40:12
Wow.. good fuel economy.
I burn 5g of diesel to mow 10ac... don't matter if it is my ford 5000 and 10' mower.. or my 7610s and 10' mower and 3 hours of work...or 15' mower and 7610s and 2 hours of work... all stil takes about 5g of diesel..
soundguy
cj3b_jeep
05-31-2007 10:40:02
I filled it up before I started mowing tuesdasy night. Last night I hauled 1 gallon of fuel over with me and put it in the tank, which brought it up to full. I checked when I was done and it was at the same level as when I started, using about 1 gallon of fuel for three hours of mowing.
Greg_Ky
01-17-2008 08:54:54
 Re: hydroulic top link in reply to Leland James, 01-17-2008 08:50:43
You need a standard hydraulic ram and you just vent the end that you are not using. You can purchase a vent to install in the unused fitting to keep dirt, etc. from entering the ram and scoring the cylinder. HTH
buickanddeere
05-31-2007 10:35:00
Just exactly how are you measuring the fuel? Are you using clock hours or tach hours?
Coloken
05-31-2007 10:32:45
My push lawn mower uses more than that.
Lou
05-31-2007 11:54:35
 Re: Tractor fuel use in reply to Coloken, 05-31-2007 10:32:45
Ive got a 3 cylinder and 4 cylinder perkins diesils, and unless your working them hard like plowing, I think they run on air.:>}
