Tractor Talk Discussion Forum
1030 case idle set
Dairy Farmer in
05-30-2007 18:03:29
alright i'm tired of having to kill the tractor everytime i want to shut it off. i know i'm sopposed to be able to put the throttle leaver all the way up and it should shut off but mine don't. where and how do i set the idle. also i was curious, my fuel pump says gremany on the side. what does this mean?
thanks in advance
DFinWI
No tools
05-30-2007 19:34:30
 Re: 1030 case idle set in reply to Dairy Farmer in WI, 05-30-2007 18:03:29
The long threaded rod along beside the engine on the right side of the engine.
Should have a short rod about 12in long attached to the inj pump.
Well on the long rod it needs to be lenghtened.
There is two nuts on the Rearward end of the rod.
Back the back one off and follow up to it with the other.To get the desired length you want to kill her out.Check under the foot throttle heel to make sure its not packed full of dirt and rock.
Had that happen also.Holds her way up on idle.
Now the name on the pump Germany. It was built in Germany.
