Tractor Talk Discussion Forum
Overheated 8N .....What to do
Spitfire
05-29-2007 10:52:53
Radiator clogged before I realized it and overheated engine and stopped running...
I waited an hour and it cranked but did not sputter or start...I did not want to push the issue so I stopped cranking after a few tries...
Any tips or suggestions appreciated
old
05-29-2007 13:13:20
 Re: Overheated 8N .....What to do in reply to Spitfire, 05-29-2007 10:52:53
Front mount or side mount distubutor?? If front mount you may have cooked the coil and if you did it will not run. First this to do is check to see if you have a good spark, and then go from there
