Tractor Talk Discussion Forum
IH 444 WITH FRONT LOADER
UWE MIEGEL
05-23-2007 07:12:38
I AM LOOKING FOR A DRIVESHAFT FOR THE HYDRAULIC PUMP OF A FRONT LOADER .INTERNATIONAL 444 DIESEL. THE SHAFT IS APPROX 13.5 INCHES LONG WITH KEY ON ONE END AND HOLE IN SHAFT AT CRANK PULLEY SIDE(ID 3/4 INCH)ALSO NEED FLEX COUPLING FOR THE SAME SHAFT THAT MOUNTS TO 3 HOLE PATTERN FLANGES.
hector gemme
05-23-2007 09:38:36
 Re: IH 444 WITH FRONT LOADER in reply to UWE MIEGEL, 05-23-2007 07:12:38
I have a shaft 3/4 with a plate a top with joint and a hole .690 inch with key but he is 11 1/2 and missing the speacer betwing the crankshaft puly with 2 dole pine .
UWE MIEGEL
05-23-2007 10:40:45
 Re: IH 444 WITH FRONT LOADER in reply to hector gemme, 05-23-2007 09:38:36
I WILL REMEASURE THE SHAFT ON FRIDAY WHEN I WILL BE HOME AND GET BACK TO YOU
THANKS
