Tractor Talk Discussion Forum
OT Vegetable diesel injectors
bm3501466
05-23-2007 06:55:21
I have been doing research on running straight vegetable oil in diesels. I have found that high pressure injectors aid in preventing carbon build up. I have a 6.5 diesel and I was wondering where I could find high pressure injectors? Thanks, Josh
Ludwig
05-23-2007 10:45:06
 Re: OT Vegetable diesel injectors in reply to bm3501466, 05-23-2007 06:55:21
Bob is right. If you've done any investigation of reputable sources you'll have found that heating the oil is the way to go...
Thats if you want to run 100% veggie or run waste veggie oil. Lower percentage requires less modification. I've run 20% just mixed in with the diesel with no issue.
Bob
05-23-2007 07:42:48
ANY diesel shop can tell you what injectors you have, and if they can be shimmed a bit to increase "pop pressure".
The turbodiesels have higher "pop" injectors than the non-turbos, and IIRC, there "marine" injectors are set higher yet. "GOOGLE "6.5 marine injectors" for more info on those.
Remember, increasing the "pop pressure" will put a lot more strain on the injection pump, too.
