Tractor Talk Discussion Forum
Massey Ferguson manure spreader
tjh72
05-22-2007 15:43:48
I borrowed a Massey Ferguson 160 manure spreader and the web broke when I started to spread manure. I fixed the web. I put a new slant in it and replaced some of the links. Now some of the slats catch on the boards as that come around the front of the spreader. The slats are in no worse shape than before. I am not familiar with manure spreaders but I noticed the front sprockets could be adjusted forward and backwards. Will this adjustment correct the slats from catching on the boards? If so, which way do I need to go with the sprockets? Thanks for your help.
Tjh72
IaGary
05-22-2007 16:19:52
 Re: Massey Ferguson manure spreader in reply to tjh72, 05-22-2007 15:43:48
Those adjustable sprockets are to tighten the web chain.
Chances are the web bars are bend down in the middle if they are catching on the front of the floor.
Put a 2x4 under the center of the bar or slat and jump on the ends.
You may need a partner for this.
Now if the web is real loose it may help to tighten it.
Gary
