Tractor Talk Discussion Forum
Bleeding 784 International tractor brakes
Lloydie
05-22-2007 01:16:04
Could anyone please suggest ways, or links, to assist me in bleeding the brakes of a 784 International tractor?
Appreciated,
Lloydie
Lloydie
05-25-2007 18:27:20
 Re: Bleeding 784 International tractor brakes in reply to Lloydie, 05-22-2007 01:16:04
Hi Guys,
Greatly appreciated for the responses. Have printed out your suggestions and will give it a go. Will let you know.
Thanks again - big help!
Lloydie
richard in nz
05-23-2007 04:02:58
Trans oil at working temp, at correct level.
Tractor engine running at 1,000 rpm.
Block off return tube to transmission at T piece near the bulkhead (firewall) with a pair of vice grips with protected jaws. (You will see the brake top up supply, clamp off the "overflow" that goes back to the trans so the brake master cylinders get all the available oil)
Attach pipe from the bleed screws and put the other ends of the pipes in to the trans filler cap, clear pipe is best.
Latch the brake pedals together and slowly pump the brakes.
When the first pipe becomes clear of air, tighten the bleed screw and continue pumping untill the other side bleeds clear.(keeping the brake pedals latched gets all the air from the balance valve)
Thats how it was taught at the training school at IHC in Doncaster where your tractor was built and you will find is the most reliable method even though long winded.
georgeky
05-22-2007 07:27:33
There is no need to pump the brakes. They are hydrostatic, just hold the brake pedals down with something and let the tractor run it will bleed itself. I do use the clear hoses like mentioned and return them in the filler hole, that way I can see when all the air is out.
ben brown
05-22-2007 03:10:38
i ues clear plastic line that well fit tight on bleed port top of axle housing then run over seat bacd down in to hy fill. that way you can pump the brakes tell you see fluid with out air bubbles. then cloes blead port.
Jrry
05-22-2007 06:50:59
 Re: Bleeding 784 International tractor brakes in reply to ben brown, 05-22-2007 03:10:38
If he doesn't have a clear line he can take a regular hose and put the end in a small bucket of hy fluid and pump the brakes. He will be able to see the bubbles blowing through the fluid and when the bubbles quit the air is out and the bleeding is finished.
Ken Macfarlane
05-22-2007 05:26:23
Its been a while but on the one with a cab I did you had to lift the floor panel and you could slip a wrench in while holding the pedal down. Its been 5 years or so though.
