Tractor Talk Discussion Forum
Ford 600 series
Arnold Ison
05-21-2007 18:14:26
I am buying a 1956 was told 600 ford tractor how do you tell what model this is.
Jim.UT
05-22-2007 07:31:23
 Re: Ford 600 series in reply to Arnold Ison, 05-21-2007 18:14:26
Look where Billy has shown you. The model number will be a three digit number. The serial number is stamped just below the model number. It will be something between 77271 and 116367 if it's a 1956.
The three digit model number will start with a 6. Possible model numbers are: 620, 630, 640, 650, 660. The model number tells you which transmission it has and a few other items. Here's a brief synopsis:
620: bare bones model with no hydraulics and pto optional. 4 speed trans.
630: Step up from the 620. Has three point hitch, but no proofmeter. 4 speed trans.
640: Another step up. Probably the most common model of the 600 series. Has pto, three point hitch, proofmeter.
650: Same as a 640 except with a 5 speed trans.
660: Same as a 650 except for the addition of a dual clutch and live pto. All other 600 models have transmission pto.
Arnold Ison
05-22-2007 09:10:33
 Re: Ford 600 series in reply to Jim.UT, 05-22-2007 07:31:23
Thanks, it has a 4 speed and pto 3point hitch It has a rear wheel seal leaking on the brake shoes is this hard to change Arnold
Jim.UT
05-22-2007 15:46:47
 Re: Ford 600 series in reply to Arnold Ison, 05-22-2007 09:10:33
Get a manual....not an I&T manual, but the Ford factory shop manual with the red/black cover. Reprints are readily available from most online tractor parts suppliers for $18 - $25. There's usually half a dozen of them on ebay on any given day.
I've done that job and while I wouldn't call it easy, it's definitely do-able. But you'll want a manual. You'll need a torch, a good drill and a good sharp chisel. There is also a bearing puller described in the manual that most people won't have, but I can help you construct one that works out of ordinary materials. Contact me for details after you've read about the procedure in the shop manual and are ready to proceed.
Jim
arnold Ison
05-22-2007 18:21:26
 Re: Ford 600 series in reply to Jim.UT, 05-22-2007 15:46:47
Thanks for all the information I'll get a manual
Billy NY
05-22-2007 05:11:38
This photo might help:
third party image
old
05-21-2007 21:29:25
Left side of the tractor just behind the starter under the battery theres a flat spot with both the model # and serail #. if its a 1956 it would be a 601
Jim.UT
05-22-2007 07:24:32
 Re: Ford 600 series in reply to old, 05-21-2007 21:29:25
Don't want to dispute, but the 600 and 800 series were sold in '55, '56, and '57. The first 601's were built in late '57 and offered for sale in '58 through '62.
Ken Crisman
05-21-2007 19:04:00
Go to John Smiths website . Its a great site with clear instructions where to find the numbers . Is it a 4 speed or 5 speed ? God bless, Ken
n8terry
05-21-2007 18:37:52
model number should be stamped into casting on top of clutch housing.
