Tractor Talk Discussion Forum
O.T. dismantling pole barn
herald
05-18-2007 17:18:09
What can you cut ring shank nails with. Am helping take down a pole barn, got the steel off, started on the wood and it is all nailed with steel nails. Any ideas on removing the nails? Thanks
john d
05-19-2007 09:03:50
 Re: O.T. dismantling pole barn in reply to herald, 05-18-2007 17:18:09
I had an old pole barn that was put together with those nails. I dismanteled it with a half-gallon of diesel fuel and a match.
Jaker2
05-18-2007 20:04:28
Make you a lever to sit against the truss or the poles which ever you are doing first and pry them up or out. You will do less damage this way and can then just drive the nails out. Hopefully the 2x's are not soft and the nails will pull out of the post and the truss instead of pulling through the board. I have take many building down and this is by far easier than trying to cut them.
Hoenes
05-18-2007 18:01:52
Get a saws-all [re-sip saw] with a 12 inch metal cutting blade and slip it in between the post and the horizontal 2 x 4 's. It might help to tap them out a little ways from the post with a sledge.
RayP(MI)
05-18-2007 19:36:45
 Re: O.T. dismantling pole barn in reply to Hoenes, 05-18-2007 18:01:52
Better get several blades, those nails are tough customers!
