Tractor Talk Discussion Forum
Fence corners
Rick Kr
05-13-2007 19:21:24
Kids have talked me into a 100" x 100" duck pen, built around a little water hole.
I havent built a fence since I was a kid, handing tools mostly.
I have the corners posts set (6"). Should I build a standard H corner and drill through the horizontal brace and use re-rod? I think that is what I remember. Then just leave a little a little rod exposed to wrap the wire around so it doesnt slip?
Not sure if H corners are overkill for 100x100. But I figure you still need them if you are going to stretch the fence at all.
Thanks,
Rick
Rick Kr
05-14-2007 09:18:53
 Re: Fence corners in reply to Rick Kr, 05-13-2007 19:21:24
Thanks for the answers. Sounds like I will stick with using standard H corners.
Rick
Mike (WA)
05-14-2007 08:31:39
Don't know about the re-rod, but the standard corner set-up is horizontal brace from corner post to next post (I put the two posts 7 feet apart, so I can use a fence post as the horizontal brace), then wire from bottom of corner post to the height of the horizontal brace on the next post, and tighten with a handy stick.
NEsota
05-14-2007 06:26:14
It is my opinion that it is best to put the horizontal cross piece up high on the vertical posts, rather then mid-way up.
Steve Crum
05-13-2007 20:08:50
I think you would be pretty safe just setting your corner post and using diagonal braces to stakes driven into the ground. My 75' square backyard fence is woven wire and tightened with a tractor, it has been in place for 16 years, 2 kids and 4 labrador retards.
in-too-deep
05-13-2007 20:58:33
 Re: Fence corners in reply to Steve Crum, 05-13-2007 20:08:50
Hahaha! Never heard that one before! I like it lol.
Incorprated
05-13-2007 19:45:46
100 inch x 100inch is pretty small.
Rick Kr
05-14-2007 09:21:03
 Re: Fence corners in reply to Incorprated, 05-13-2007 19:45:46
You never know maybe I am raising minature ducks.
By the way, shouldn't your handle be spelled Incorporated, not Incorprated.
Not that I am the picky one.
RayP(MI)
05-13-2007 20:25:10
Often when you post here using the apostrophe, it comes out as a quote mark. Surely, he meant feet, not inches. As far as corner posts, he needs to put them in very well supported, we used diagonal braces to next posts, and then diagonal wire in other direction twisted tight. shetland sheep or a couple llamas will stretch a fence to unbelievable amounts, ask how I know!
Uncle Ernie
05-13-2007 20:56:11
 Re: Fence corners in reply to RayP(MI), 05-13-2007 20:25:10
Don"t call him Surley! And 100"X100" is plenty for a duck!
