Tractor Talk Discussion Forum
3 pnt hitch
ruff neck
05-13-2007 09:05:18
recently purchased mf65 (1958) i believe. tractor seems to run fine only i can't seem to get the 3 point hitch to raise. i was under the impression that the two levers that slide on my right hand side would raise and lower the hitch but it dosen't seem to move no matter where i postion the levers. raise-lower & float. am i missing something? seems to be full of oil. help.
Gerald J.
05-13-2007 10:17:11
 Re: 3 pnt hitch in reply to ruff neck, 05-13-2007 09:05:18
One lever is for draft control. It has to be all the way up for the position control lever to work. If there are valves under the front of the seat for the remote, the left of them has to be latched forward for the levers on the right to run the three point.
Gerald J.
ruff neck
05-13-2007 14:24:01
 Re: 3 pnt hitch in reply to Gerald J., 05-13-2007 10:17:11
no valves under the seat. draft and position levers all the way up. still no response. am i missing something? it was up when i got it.
Gerald J.
05-13-2007 16:21:11
 Re: 3 pnt hitch in reply to ruff neck, 05-13-2007 14:24:01
Pto turning?
Gerald J.
ruff neck
05-13-2007 19:20:08
 Re: 3 pnt hitch in reply to Gerald J., 05-13-2007 16:21:11
yep pto turns when engaged.
