Tractor Talk Discussion Forum
Woods Mower
37 chief
05-11-2007 20:46:54
I have a 6 ft woods mower behind my MF 231. For some reason the rear wheel doesn't track staraight all the time. Sometimes it gets cocked a little leaving a skid mark. the bearings in the frame shaft, and wheel are ok. Any body have any ideas what would make the wheel not track straight? Thanks Stan
in-too-deep
05-12-2007 05:09:36
 Re: Woods Mower in reply to 37 chief, 05-11-2007 20:46:54
The beam where the tail wheel is mounted should be secured to the mower frame without being all wobbly. If the bolts are all worn out, get yourself some hard bolts and nylon lock washers to cinch everything up with. If it's already tight, chances are the shaft on the tail wheel is bent slightly. It doesn't take much because it's a fairly close tolerance, but it'll be a job getting it straight so it won't bind.
Duner Wi
05-12-2007 04:57:47
Shaft that pivots is probably bent a little bit.
Allan In NE
05-11-2007 22:08:44
One thing at a time.
What's the story on the transmission in the truck?
Allan
37 chief
05-12-2007 18:13:53
 Re: Woods Mower in reply to Allan In NE, 05-11-2007 22:08:44
It acted ok friday morning. It only does this very seldom. When it does I get that sick feeling, but then it goes as normal. When I get a cnance I am going to pull the pan to see what I can see. Stan
dds-inc
05-11-2007 21:03:03
Pull the shaft out and inspect it.
