Tractor Talk Discussion Forum
1941 a john deere
zac terry
05-10-2007 06:33:10
i'm trying to switch from my remonts to my rockershift arms to run so cultivators thanks zac
John T
05-10-2007 09:22:38
 Re: 1941 a john deere in reply to zac terry , 05-10-2007 06:33:10
Dennis is right on the money. To switch from remote cylinder operation to rockshaft rotation on a JD Power Trol , you have to EITHER change the rear horizontal power trol plugs or else if you have one of the adjustable top plugs you remove the outer dust cover cap and turn the lil knurled selector knob to change. What youre doing is diverting the pumps hydraulic fluid from the remote couplers to the inner cylinder which raises the rockshafts. The different plugs have open holes or blocked passages depending on which way the oil is to flow.
John T
DennisV
05-10-2007 06:43:00
Do you have the dummy plugs to replace the remote cylinder plugs. They are needed to get the rocker arms to work on most of the 2cyl. John Deere"s. Not sure which type you need, but I think that could be your answer.
