Tractor Talk Discussion Forum
MF Puzzler????
Devin Sparks
05-09-2007 14:30:57
I picked up my MF 3525 today after a long stay at the repair shop. I had clutch and slave cylinder replaced. I drove it home about 20 miles. After returning home a hooked to a plow and went to the field. After making a coulpe of passes the tractor would not hardly move. I had to limp back to the house in Low 1. After a nap due to having to work tonight I went back and tried again. Now it takes off in Low and High gears. Whay would cause this. Did the trans grt to hot. Any ideas? I called the repair shop and talked to them just to report it and they said to try it in the field again and let them know. I believe the clutch is slipping a little. I will try it again and if any problems I will send it back. I know someone here may have an answer.Thanks
ken in texas
05-09-2007 16:50:00
 Re: MF Puzzler???? in reply to Devin Sparks, 05-09-2007 14:30:57
Need alittle more information on what it,s doing.Like does the motor rev up but tractor doesent move much,like maybe a slipping clutch,or engine pulls down like the brakes are locking,or trans locking,or not getting enough fuel orsomthing else.
Devin Sparks
05-09-2007 20:47:02
 Re: MF Puzzler???? in reply to ken in texas, 05-09-2007 16:50:00
It feels like thwe clutch was slipping. But then it would not move at all with out reving the motor very hi and then it will start to move slowly. I went back out after posting this and it worked fine. Pulled the chisel plow in hi range 1 with out any problems. I will ride it some and see if it happens again.
