Tractor Talk Discussion Forum
MF 50A Backhoe-Loader Fan Belt
Kaz
05-09-2007 09:30:00
I have a Massey Ferguson 1972 50A Tractor Backhoe-Loader, it is quite old, and always needs something. The latest thing is the fan belt, so I went to the local parts store and picked one up, but when I tried to install the crankshaft comes out of the main pulley into the frame. Is there a way to bypass this? Do I have to take the whole front end apart? Should I just call the local guy who fixes tractors? Please help!!!!
Leland
05-09-2007 18:35:13
 Re: MF 50A Backhoe-Loader Fan Belt in reply to Kaz, 05-09-2007 09:30:00
welcome to the world of heavy equip repair ,now you know why some shops charge 100.00per hour +
Ken Humbert
05-09-2007 16:36:52
I have a ford 601 with the same setup and am replacing the belts right now. This is not fun, and those put togeter belts don"t work, been there and tryed that.
Johnski
05-09-2007 13:59:55
Check this out. Fennerindustrial dot com. They sell v-belts that are made up of links so you can make one any size and put it on without taking the whole tractor apart. Grainger and McMaster-Carr should also have something similar. HTH,Jf
Tom N OK
05-09-2007 09:41:58
My guest is that shaft drives the hydraulic pump, probably in the front of the tractor....so would have to remove from pulley and move the pump enough to install the belt.
Have fun
Tom
