Tractor Talk Discussion Forum
P.T.O. speed
Don c
05-09-2007 09:18:43
Since I'am not a farmer and only have 1 old JD that just gets drove around I have been thinking about this question. At what engine speed does the PTO reach the normal 540 rpm. or is it 540 all the time and when you change engine speeds it doesn't affect the PTO speed. Thanks for any and all answers..
Walt Davies
05-09-2007 11:03:21
 Re: P.T.O. speed in reply to Don c, 05-09-2007 09:18:43
At working speed that would about 3/4 to full throttle it won't brake anything if over revved as long as you haven't turned up the Governor like I did on my Case LA.
Its pretty much a standard thing that lets people know what PTO is on their tractor. they come in either 540 or 1000 or both and your equipment will say which it wants to run at.
It nothing complicated just set it for what it calls for and don't get excited about not being right on 540 or 1000.
Walt
Tom N OK
05-09-2007 09:58:18
Hi Don Most old tractors should obtain PTO speed at approx. 3/4 throttle. If you happen to have a working tach on your tracotr...it has PTO indicator on it.
Tom
RAB
05-09-2007 09:37:10
Most or all are rated at a compromise engine rpm between power/torque availbility and economy and this rpm will depend on the engine used (and sometimes even a variant of that engine). Most pto rpms are related to engine speed. There may always be one or more which are different. After all, we are in the times of micro-chip tecnology, so near anything should be possible if required.
Regards, RAB
Glenn F.
05-09-2007 09:32:06
Don:
The pto runs at 540rpm when the engine is at a specified rpm. The owners manual will tell you what that engine rpm is but it will be nearly full throttle.
Glenn
