Tractor Talk Discussion Forum
Sears surbuban SS18 tractor fuel pump
Aj Suess
05-09-2007 06:27:24
I'm having problems with my tractor running at high are RPM's it has to be choked, at mid RPM it runs fine I have checked the fuel pump I think there is a spring missing the works with the disk behind the pumping diaphragm .The vacuum pumps on outbord motor (Evindude 9.9) has this call it a return spring If there should be one anybody knows if my suspicion is right where i can purchase it . I know that Cummins has bought out Onan and are suppying Onan parts prices are crazy the fuel pump and gasket set is $418.00 CDN any ideas guys
AJS
Jim in Ma.
05-09-2007 17:47:09
 Re: Sears surbuban SS18 tractor fuel pump in reply to Aj Suess, 05-09-2007 06:27:24
I run 2 sububan tractors for cutting my lawn - both fuelpumps quit so I just bypassed them = they wotk fine but have one problem , you cant drive up hill.
On flat ground they work fine.
circus
05-09-2007 07:27:33
If you really think it's the pump a electric pump costs about $40. Beware though it'll keep pumping if you crash at 60 mph.
Bob/Ont
05-09-2007 07:18:23
Try all the Small Engine places around your area. They likely have some old Onan's laying around they have replaced with other engines. Also there is a very small seal on the carb adjusting screw, check that isn't cracked.
Later Bob
