Tractor Talk Discussion Forum
Old Wheel Horse
Woodchopper
05-09-2007 02:56:49
I found a 1980 60" cut Wheel Horse tractor with a 4 cyl water cooled Renault engine that doesn"t run. I was told parts weren"t available - does anyone know where parts can be found?
Thanks, Dennis
Duner Wi
05-09-2007 19:17:35
 Re: Old Wheel Horse in reply to Woodchopper, 05-09-2007 02:56:49
Type renault in the garden tractors forum. Quite a bit of info there.
Chris(IA)
05-09-2007 07:41:18
Jacques Renault Parts in California should have anything you"d need. I just bought a set of points for my 61 Caravelle at O"reilleys auto parts--Napa said unavailable
JT
05-09-2007 06:09:42
Yes, you are correct, there are very little parts avaliable for the engine and not even much left for thew tractor. It is a brute of a tractor, but did not go ver well when they came out. You might be able to find a few parts through NAPA or a good auto parts store, but things for it will be slim to none in the way of parts for the engine.
Duner Wi
05-09-2007 05:01:21
I don't know about Wheel Horse but Toro around 1980 used the Renault 4CV engine from about 1960. Little push rod 4 , wet liners. Same engine in Dauphine with little more cc, dist and carb. Parts for the car engines should not be impossible. Good Luck!
Oldmax
05-09-2007 04:57:53
That would be a rare breed they made them a few years I remember looking at them when they came out .
Gary penfield
05-09-2007 04:31:53
I have a Case skid steer W/aFrench Renault engine, if it has a tag on engine, try midamerica powercenter 800 328 0916
