Tractor Talk Discussion Forum
John Deere 790 Bent Pushrod
Bob Blake
05-07-2007 16:09:50
I think I bent a valve of pushrod on my 790.
After sitting all winter the tractor would not start and I thought it was not getting fuel. I poured some fuel in the intake and got it to start. It would not stay running so I did this several times.
I later found out it was the "PTO" fuse which I guess did not allow it to get fuel. Once I replaced the fuse the tractor ran but had no power. My friend thinks that the excess fuel probaly bent a pushrod or valve.
Is it a big job to repair something like this?
Any help would be appreciated.
Bob
Howard H.
05-07-2007 23:37:50
 Re: John Deere 790 Bent Pushrod in reply to Bob Blake, 05-07-2007 16:09:50
Before you get too worried, do a pressure test on each cylinder - dry and then wet, to see if/where you are losing compression...
That will give you a better idea of where to start.
I'm not sure how pouring some fuel directly into it caused a bent push rod... Especially no just a teaspoon... Unless you had a valve sticking from other causes maybe...
Are you sure there are no intake or exhaust restrictions?
Or also - I had a rat eat a hole in the intake air hose which caused it to lose all power on the top end, since the turbo could'nt build any pressure.
Howard
JerryAR
05-07-2007 19:18:35
If it is JUST a push rod, it is real easy to replace. But,it could very well be more. What are the symptoms?
Bob Blake
05-07-2007 19:28:20
 Re: John Deere 790 Bent Pushrod in reply to JerryAR, 05-07-2007 19:18:35
Loss of power - feels like it's running on 2 cylinders. It still starts right up and idles fine, it just lacks power under heavy load.
Hopefully I'll get lucky and it won't be major!!!
Thanks for the help
Bob
jimtNV
05-07-2007 18:27:18
When I lived in Nebraska 15 years ago, I always had a 2040 deere that needed a tiny little bit of ether in the winter. Even as little as I used, I still know I shouldn't have used it. The one thing I wouldn't have ever done was pour a vast quantity of fuel in the cylinders.
You probably blew the head gasket out.
dds-inc
05-07-2007 18:23:31
Oh boy.
Sadly, you have just created a potential for more damage than a full can of ether sprayed up the intake.
MSM
05-07-2007 16:19:40
There is a good possibility that you made junk out of the engine.They are designed to fire with a highly atomized mist of fuel per stroke,dumping in raw fuel is the equivalent of giving the engine a half hours running times worth of fuel in 2 seconds.Clearances in a diesel are very close and by dumping fuel down the intake you could have bent connecting rods,broken piston rings,blown a headgasket or cracked the head.
Bob Blake
05-07-2007 19:23:22
 Re: John Deere 790 Bent Pushrod in reply to MSM, 05-07-2007 16:19:40
Yea, I realize NOW that I screwed up.
The tractor runs and feels as if I am missing one cylinder. I can still run a 5 foot bush-hog but it will bogg down a whole lot sooner than it use to. It doesn't run hot and doesn't smoke so I'm hoping I got away with just a small amount of damage.
I put about a teaspoon of fuel down the intake.
Are they fairly simple to work on? Can I pull the valve cover off and get to the pushrods and see what is going on?
Thanks for the response.
Bob
buickanddeere
05-07-2007 21:30:18
 Re: John Deere 790 Bent Pushrod in reply to Bob Blake, 05-07-2007 19:23:22
Odds are cylinder over pressure is not going to bend a pushrod. The damage was likely done to something like a head gasket, piston or connecting rod. A push rod gets bent if the engine is out of time, over revved or has a valve stuck in it's guide.
