Tractor Talk Discussion Forum
oil filter WD45
Dal Dunagan
05-05-2007 13:33:58
I have a 1969 WD45 Allis Chalmers. I was told to get a NAPA 7011 oil filter. The problem is that there is a pipe that comes from where the oil filter attaches, that goes thru the oil filter. The problem is that the new filter has no provision for this pipe. What is the remedy for this situation? Do I have wrong filter or is there a procedure to get around this. Thanks to any helpers, in advance.
johnski
05-05-2007 15:59:17
 Re: oil filter WD45 in reply to Dal Dunagan, 05-05-2007 13:33:58
NAPA filters are made for them by Wix. If you drop the first digit from the Wix part number that will be the NAPA part number. So the number Old gave to you Wix #51101 would be NAPA #1101. HTH Jf
Gerald J.
05-05-2007 14:54:15
If the filter isn't filled with cotton, its the wrong filter that will kill your engine from lack of oil pressure.
Get the right filter filled with cotton.
Gerald J.
old
05-05-2007 15:09:12
 Re: oil filter WD45 in reply to Gerald J., 05-05-2007 14:54:15
The Wix 51101 is one of those that works well on the WD45, wix fixed the problem with them a number of years ago
old
05-05-2007 13:53:26
Sounds like you have the wrong filter. By the way is that a miss type on the year?? There never where any WD45 made in 1969. I use Wix oil filter 51 some thnig or the other, can't rememeber all the number
