Tractor Talk Discussion Forum
hydraulic pump removal on 8N tractor
papa ron
05-05-2007 09:53:02
Have 1951 8N Ford. Having problem removing hyd. pump. NEED TO KNOW HOW TO REMOVE FROM HOUSING. THANKS
Bob
05-05-2007 10:08:29
 Re: hydraulic pump removal on 8N tractor in reply to papa ron, 05-05-2007 09:53:02
Have you first removed the PTO shaft by removing the 4 bolts holding the bearing housing to the rear of the case, then pulling the PTO shaft rearward, out of the pump?
If you've done that, the pump is simply stuck to the gasket, and when it lets go, it will FALL out.
Be careful when re-installing the pump... there is a control arm hanging down from the top lift cover that has to properly engage with a lever on the pump as the pump goes back up.
papa ron
05-10-2007 14:12:11
 Re: hydraulic pump removal on 8N tractor in reply to Bob, 05-05-2007 10:08:29
thanks Bob,came right out. Gasket leaking. paparon
papa ron
05-05-2007 10:37:32
Thanks Bob,that was quick. No,did not know that. It's raining here today,can't get to it. Will let you know later. Thanks again.paparon
