Tractor Talk Discussion Forum
O/T Saturn flasher unit
nwb
05-05-2007 03:56:03
The turn signals and flashers went out on my daughters car the other night. I stopped in at Advance Auto and they had a choice fo two. I went out and looked in two fuse boxes and could find nothing. Would any of know where they put these things and if they are called something else? My daughter is getting tired of hanging her arm out the window. Thanks.
Thunderr
05-05-2007 18:45:49
 Re: O/T Saturn flasher unit in reply to nwb, 05-05-2007 03:56:03
I have the same thing on my 05 ion. Except i dont hang my arm out the window. Checked the fuses, forgot to look for the flashers. Would they be in the same locations on this model?
Owen Aaland
05-05-2007 16:32:27
I just checked the location on my '96 SC1. It appears the flasher unit is now located on the back side of the IP fuse panel. Remove the left cover and it should be just above the chime module which is about 1 1/2 inches wide and 3/4 inches high. The flasher unit looks like a relay switch, about one inch square.
noncompos
05-05-2007 10:51:24
If nothing here helps try saturnfans.com; it"s a pretty complete site with good forums. Good luck.
Owen Aaland
05-05-2007 06:18:55
'95 Saturn has the flasher unit located in the instrument panel fuse block. This is the fuse block that is located on the right front side of the center counsel, not the one under the hood. The panel cover is held on with velcro. The flasher location will be listed on this panel cover.
Sam#3
05-05-2007 06:02:16
Check in the wire bundles around and above the steering column for the flasher units. Some are just hanging in the air, so to speak. Of course if they "went out" maybe they will return later. :)
nwb
05-05-2007 04:04:46
Oops, I forgot to mention that it is a '95 SL.
