Tractor Talk Discussion Forum
slow 3ph
jakers
05-03-2007 04:29:58
I have a Long tractor that has a 3ph problem I was hoping for advice on. When the tractor starts cold, the 3ph arms will not lift up at all. I lift the control and it does nothing. Eventually, after 10-15 minutes warming up, it starts to creep up. I can help it along by reving a bit. But not much. Then when its up, I can drop it and it will lift ok. I left up for an afternoon and it doesnt creep down. Its got a TDH reservoir, and I have TDH in it, and its to the right level. There is also a loader, but it works 100% from the start. The loader is plumbed right.
Any ideas or is this life with a TDH tractor? It takes time?
souNdguy
05-03-2007 12:13:51
 Re: slow 3ph in reply to jakers, 05-03-2007 04:29:58
I'm not familiar with your tractor.. but is it possible that you have a suction leak on your hydro pump and it is loosing prime and taking a bit to prime up?
If you have any diagrams onthat tractors hydro system post them.. maybee we can read thru them and point you inthe right direction.
soundguy
soundguy
