Tractor Talk Discussion Forum
Case VAC fuel bowl
Jeff H1
05-01-2007 12:31:33
Will a case VAC run ok if the glass fuel bowl is removed and an inline filter put in it"s place?Or does it require the fuel to be held in reserve for the carb?
Thanks
Jeff
in-too-deep
05-02-2007 07:02:32
 Re: Case VAC fuel bowl in reply to Jeff H1, 05-01-2007 12:31:33
If you do decide to go that route, make sure you get a filter designed for a gravity system and not a pressure system. They're built differently. I think you should stuck with the sediment bowl, though. Good luck with whichever you decide.
gene bender
05-02-2007 02:11:49
when getting a new to me tractor i use the FRAM see thru filters as you never know what you can find in the gas tank just get the filter pointed correct
Kansas Cockshutt
05-02-2007 00:03:40
NAPA has a brand new glass sediment bowl type filters/ water seperators with shutoff and new filter screen for not much more money then the cost of the amount of inline fuel filters you will go through... turn off fuel, loosen bail, dump water and dirt, re attatch, shut off will keep your crankcase from filling with gas if your float sticks, so much nicer then an inline filter, but it YOUR tractor so do as you wish!
Paul from MI
05-01-2007 17:21:27
I use an automotive type inline filter between the sediment bowl nad the carb on my "using" tractors where the "corrrect police" don"t have jurisdiction. It may not be necessary, but it doesn"t hurt anything and if it prevents one carb cleaning or delay it"s worth it. Filters are cheap and keep some crud out that might pass otherwise. Just my opinion, not worth much.
Paul
Joe (Wa)
05-01-2007 14:32:00
I agree with Glenn & RAB. Also consider the shut-off valve incorporated in the sediment bowl. Even a good working carb can leak-bye the float valve occasionally. You would be wise to have a shut-off valve especially if parking inside.
The sediment bowl inlet picks-up 1/2" - 3/4" above the floor of the fuel tank, you're going to want to duplicate that if you remove it.
The sediment bowl is designed to trap moisture from condensation or whatever, most gas filters wouldn't.
Joe
Glenn F.
05-01-2007 13:57:22
You can't improve on a sediment bowl. They are high capacity and are easily cleaned out/re-used. Tractors are designed to work in some pretty dirty conditions. You'd be surprised how much dirt those things catch. There's no way I'd replace mine with anything.
Glenn
RAB
05-01-2007 13:53:17
Yes and no. The sediment bowl is already a filter, presuming the gauze disc has not been discarded. When new it was perfectly adequate to cope with both particulate and liquid contaminants in the fuel. It is a visible indicator of fuel flow and condition, as far as the fuel is concerned and is easily cleaned if excess contamination is observed.
Your fuel tank is the reserve for the carburettor. So, no, it is not needed for that.
By all means you can replace it with a SUITABLE low pressure drop device so as to retain flow at the low pressure head of a near empty tank but, I would ask, why do that? The existing item was, and still is, a superb piece of kit to do the job it was designed for - fuel tap, filter and sediment indicator. Your new in-line filter will not indicate when the pressure drop is too high, will not prevent blockages any better than the former and will filter out smaller particles (which would do no harm anyway) and may block prematurely with liquid contaminants or pass them through to the carb causing extra running problems. IMHO bad move, but your choice.
Regards, RAB
