Tractor Talk Discussion Forum
john deere b
jonathan s
05-01-2007 10:10:02
hey guys, i can"t get my platform off my john deere b. i have been soaking them in pb blaster but the two screws havent gave up yet. i dont have acess to torches. any help will be very much apericiated. thasnks again, jonathan s in northeastern pa
MLD
05-03-2007 05:07:18
 Re: john deere b in reply to jonathan s, 05-01-2007 10:10:02
I had to drill the heads off, then get the rest out, I think with vise grips. I put hex head bolts back in place, they stick up, not flush, but at least I can get a socket on them.
Paul Janke
05-01-2007 11:59:17
Best I have seen for screws is a screwdriver which is steel all the way through the handle. Hammer on it with an air hammer while turning it with a wrench or vise-grips.
Mike M
05-01-2007 11:37:50
Do you have an air hammer ? put a tool in it that resembles a punch and start at the edge of a slot working at an angle in the loosen direction.
I have used a punch and a BFH and done them by hand too.
origionaly jd-tractor
05-01-2007 11:34:01
Had the same problem when I did my B ,I ground off,chopped with a chisel to get the heads off to remove the platform,then was able to free up the threaded shanks of the bolts with penetrating fluid to get the bolts outyou also could use a drill to drill off the flared head of the bolts
